AC symbol won't go when on demist
leegt5
232
Can someone clarify if this is correct.
Set the car to demist and the AC symbol comes on Automatically and you press the AC button and it won't go from the screen !! Is this correct ??
If so is the aircon actually on seeing that it is only 3 degrees outside or is it just showing it on the screen as I didn't notice if the engine note dropped and was fiddling with the button trying to get rid of the AC symbol !!
Forbez
Huge Member!
Feb 11, 2004
5,878
S.Wales
Visit site
I get that sometimes, just adjust the air speed and temp, and you should be able to turn the AC off, but i wouldnt expect it to come on at tht temp anyway.
When you say set to demist, you mean, putting the heaters on to the windscreen yeah?
Oct 17, 2006
893
Walthamstow
Mine comes at low temps aswell...other night it was about 4 degress, and whacked the heaters on and the AC comes on - not really an issue as it does turn off when i press it - just can forget sometimes
roundy
134
Hampshire, UK
Mine does eaxctly the same and I can't turn it off, it's probably a feature! Having A/C on does keep the windows from steaming up and clears them a lot quicker.....
i just stick mine half way between floor and screen - sorts the A/C prob
leegt5
232
I've worked out what it is...
When you demist the windscreen if the engine is not up to 90 degrees you can't turn off the AC. Then when it reaches 90 you can turn it off !!
Roundy love your siggy !!
