If you have factory fit Sat Nav and have the correct disk you should have dynamic navigation that routes around jams...
They were apparently built by SEAT Sport but not sure about the hand-built thing!
temperature gauge doesn't read temp properly until the engine has been running for 5 mins
The temperature thing does indeed work..... got in it this morning, and 5'C popped up instead of the time !!!
fuel calclation is based on consumption during last 50Km
l
eeeeemmm how do i access this fuel calculator ? Where is it ?
Tucking the rear middle seatbelt catch down the crack between seat and seatback is essential unless you like a constant clacking coming from the back of the car.
Good one... that will be the bl00dy irritating noise I have been trying to find! Thanks.
Yes but thats irrelevant as you are none the wiser when you dont have them on! In other cars the telltale sign is you dont have dash illumination which is 100% obvious! Because dash illumination is automatic, it is not so obvious that you dont have your lights on! The dash illumination misleads you into thinking that they are on, your not really paying attention for the little green light to tell you they are on.!
Im glad im not the only 1 that has done it then, lol
Mine wont!But strangely a TDI FR opens even with the engine running
