how to remove your door card......pics
p34ch3y
tastefully modified
Oct 17, 2005
2,879
cambs
step 1 flick out with a small flat head, carefull not to scratch any thing
step 2, priz UP, it has to go up, not any other way else you will break it
step 3, unsrew useing phillips
step 4,unscrew the door pin anticlockwise
step 5,priz out slowly useing a trim tool...........i found this tool a life saver worth geting one
step 6,use the trim tool to slide between the door popers/clips n priz out
JOB DONE, shuold take about 15/25 min
hope this is helpfull ;)
exsaxoboy!
125
sutton BRUM
Surely taking a door card off is common sense? If people need a guide for taking the door card off they shouldnt touch there cars at all! again only my opinion, but you simply undo all the bolts and use your common sense!
