Wonder if you guys could help..
The radiatior in my girlfriend's 1.4 Ibiza had cracked at the corner, coolant everywhere etc..
So I've fitted a new radiator, replaced all the coolant and tested it for leaks..so far so good.
Taking it for a spin, or leaving it to idle causes it to overheat (Needle heading towards 110 on the temp gauge). I've noticed however, that the fan isn't kicking in.
If I disconnect the plug from the temp switch screwed into the rad, and bridge two of the pins with a wire, the fan starts (Both speeds) so I know the fan/motor/wiring etc is all ok.
I replaced the 3 pin switch in the rad and it's made no difference.
Can anyone help out please, I'm at a bit of a loss now.. for whatever reason, the fans just won't trigger at 95c when it's supposed to!
K
K
