Yes i think Si has found the inbetween between KO4 and IHI.
Its certainly worth thinking about as the way i see it you dont waste money on all the other accessories needed for a BT upgrade!
Direct bolt on to existing manifold, meaning yes james your downpipe and TIP are just fine However change to go BT and you would need a new manifold/downpipe and tip along with a lot more bits and bobs
Group buy anyone
James, ill have to speak to mike actually about nitrous mapping as i would like to stay with jabba as i have the boost controller fitted
I couldnt see why not as you can change settings with the SPS.
Its working well with Si's and he is running his standard mapping i believe, just at higher boost!
Cheers i did google there name the other day but found nowt. Bit like the eliminator then
So its a biog differnce to stock? Would lik eto see our cars side by side to see the rough differnce in power
Its shown a 30whp improvement on Si's car which is the proof in the pudding.
His last mapping was around 245ish @ wheels @ awesome. this 1 273 @ wheels @ awesome.
Like phil has said it might not even require re- remapping, if the requested boost at redline for us james is 1.3-1.4 bar then it shouldnt need touching!
If ive got time tomorrow ill register on his site and try and negotiate a group buy deal
Nope, not for me. Staying at Stage 1, thanks.
I can't remember if it has different bearings or not, I know it has a different backplate and Sie's mentioned it's supposed to have a lower shaft speed than the stock one.
4bar for safety - basically to make sure it's overfuelling (i.e. not running lean) before checking A/F ratio. Jacob recommends larger MAF to make the most, but IHI boys run S3/TT/LCR MAFs (although some "scaled") on more power
If you're going to get one, my advice would be to make sure you budget for a remap, unless you like living in fear of something going expensively wrong. Also, you'll know it's running at it's best.
Yep. a couple fo the Jabba mapped IHI boys have switch, so they can do it.
Custom-Code people wanting a suitable maps might have to ring around. Bill would perhaps be a good choice.
Edit: Oh and I have nagged Sie to get a thread started, but he's wanting to run it for a bit and get it all fully checked out on a rolling road (fuelling, boost & timing settings etc) before he posts up, so you know the full story.
Also, I wouldn't ost on Jacobs forums asking for a discount, I'd email him
