bobbyanderson@h
Hi everyone, new to the forums, I had a search around before posting with regards to my problem - I saw a few similar topics but they all seemed to have different conclusions.
Just to introduce the car a little, I have a 57 Leon FR 170PS TDi DPF, I got it with delivery mileage (25 miles) and now its sitting around 11.5k, the car hasn't been modified at all and I've never had any problems with it at all until a couple of weeks ago, I was driving into a National Speed Limit area and was sitting at about 1500 rpm before accelerating quickly up to 3000 rpm when I noticed the acceleration either dipped/stopped, I changed gears and it was fine afterwards, its happened a total of 3 times in the past few weeks twice in 3rd and once in 4th.
I had a look under the bonnet and noticed that the engine cover was loose, the dipstick was out and clips were broken on the cover - I've read on here its ok to remove the engine cover and continue to drive as normal? Is this what is also causing the cuts in acceleration or is there something else I should be looking for?
It seems s though this is more likely as it gets closer to its regeneration period. Also if you are remapped, then more soot will be being created so more chance of a glitch,
