I've now got the slow fan fault problem where the fans only work at high speed when you flick the air con on. In traffic yesterday the temperature went from 90 to 100 and then back again.
I'm working on a fix, but in the meantime can I just check it won't actually overheat because the emergency high speed fan will always kick in? It just gets above 90 because it's lost its ability to run low speed?
Should I keep the air con off so that the fan isn't constantly running at high speed?
