EPC light 1.4 TSI turbo actuator
Briant566
343
West Yorks England
Hi
Just had mine in for second service at 24 month on Monday. drove it for first time today and EPC light came on about 15 miles into journey stopped about a mile further on and switched engine on and off and it cleared ? Not been on since
Phoned garage they had not done any updates and to see how it goes on
The strange thing its exactly 12 month to the day of its Last service
Anybody else had this
Briant566
343
West Yorks England
Hi
You have got worried I have just been out and revved it up and it seem s not to be getting full rpm and seems to be limiting to 4000 rpm
to What should a 1.4 TSi Rev to according to book it should be 5000 to 6000
Just found out from dealer it has a rev limiter if stood still at 0
chrisRibiza
1,194
51
Could be a safety feature. Go drive the car and see if it revs correctly when driving.
If there's no warning lights I'd say it'll be grand.
I had EML and EPC lights on aswell as start stop error on the CAR menu.
BlackFR
1,724
Not too far away
Static revs are limited I beleive.
I had an intermittent EPC light and no other lamps. When it was on my revs were limited and most of the time I had no boost from the turbo which was extremely noticable.
Briant566
343
West Yorks England
Hi
Thanks all for input
Just been out this morning on Motorway while quieter did 89 mph in 4th at 5000rmp and up to 100 mph and then 10 mile at 75 to 80 and all seems ok
BlackFR
1,724
Not too far away
Pmerryman, is your a 1.4 or a 1.2 as per your sig?
Brian, you would definitely notice the fault under normal driving. Just keep an eye on it or drag it into a dealer for them to read the faults out if under warranty. I think there is a TSB which says something along the lines of first lube the mechanism, then replace actuator and finally replace turbo of all else fails. Obviously yours may just be a one off or not related to this at all
Briant566
343
West Yorks England
On again
Well that that theory quashed :(
EPC light came on again tonight shortly followed by the Fault in emission control system so it will be a call to dealers on Monday luckily it only 10 min up the road from me and not working
I wonder if its a loose connection from when they did the service
chrisRibiza
1,194
51
Is the fault in the emission control system the yellow engine management light?
My money's still on the turbo actuator.
Briant566
343
West Yorks England
Just a update !!
Took car in they have run a full diagnostic check and found the following
1/ EPC Light and Emission light faulty turbo actuator new turbo required !!
2/ stop start fault traced to faulty brake light new light unit required
they have also found a fault on sat nav which I have had no problems with and that is been replaced
All parts on order should be ready Thursday I good job I had two car free days planed and garage is loca
lf not complete a Loan car for Christmas
glad it under warranty
Does not say much for a 2 year old car at 12000 miles
chrisRibiza
1,194
51
Haha, I also had the stop / start error but it only happened the times the EPC / EML lights were on so it's interesting they traced that back to a brake light on yours.
(I do check my brake lights each day as I'm leaving the driveway anyway :) )
At least your all sorted!
Briant566
343
West Yorks England
My stop start fault only came on at same time as EPC so seems strange I have not noticed a brake light out wonder if it Led drawing the correct current ?:confused:
