Although this fault is fixed, I'll share my experience for others to note so how to fault find in the future.
So, there I was, travelling through Glasgow when I struck a pretty deep pothole, camouflaged by a puddle. The car started to cough and splutter, then stalled with the dash lighting up like Blackpool illuminations.
Resulted damage:
...and a car which refused to start.
What next? VCDS Scan revealed a few faults
What do the faults show? The engine won't start as the immobiliser is cutting the fuel and there is no connection to other modules in the car.
Why is the immobiliser kicking in? Somethings loose with the wiring behind the dash. The looms for all interior electrics meet at the bulkhead behind the clocks through various amounts of plugs. The immobilser in the cluster can't read the key so cuts fuel to the engine.
How can I fix it? Time for a roadside strip down...
I had a feel and play with the wiring and the ignition on. Pushing the loom would turn some dash lights on and pulling the loom would turn lights off, something's not quite sitting correctly
After an hour of wire and relay testing, I find the issue...
The arrowed white plug had worked loose and was balancing in the holder. It's the same plug I had originally removed when installing Cruise Control last year. A swift push and it clicked into place.
Result? All running and no faults found on VCDS!
Lesson Learnt? WHEN INSTALLING ANYTHING ON THE CAR, ENSURE I DO IT CORRECTLY FIRST TIME AND SECURE ANY CONNECTORS I FIDDLE WITH
Resulted damage:
Code:
Address 01: Engine Labels: 038-906-019-ASZ.lbl
Part No: 038 906 019 LA
Component: 1,9l R4 EDC G200SG 5405
Coding: 00105
Shop #: WSC 06402
VCID: 61C94306EBE9A716FBD-4B36
6 Faults Found:
18044 - Powertrain Data Bus
P1636 - 35-10 - Missing Message from Airbag Controller - Intermittent
18045 - Powertrain Data Bus
P1637 - 35-10 - Missing Message from Electric Load Controller - Intermittent
18058 - Powertrain Data Bus
P1650 - 35-10 - Missing Message from Instrument Cluster - Intermittent
17978 - Engine Start Blocked by Immobilizer
P1570 - 35-00 -
18027 - Glow Plug Relay (J52)
P1619 - 35-10 - Open or Short to Ground - Intermittent
18043 - Powertrain Data Bus
P1635 - 35-10 - Missing Message from A/C Controller - Intermittent
Readiness: 0 0 0 0 1
Address 03: ABS Brakes Labels: 6Q0-907-37x-ASR.lbl
Part No: 6Q0 907 379 H
Component: ABS/ASR 5.7 FRONT V30
Coding: 00188
Shop #: WSC 06403
VCID: 428BAC8A4E2FDC0EC27-517A
2 Faults Found:
01317 - Control Module in Instrument Cluster (J285)
49-10 - No Communications - Intermittent
01314 - Engine Control Module
Address 08: Auto HVAC Labels: None
Part No: 6L0 820 043 B
Component: CLIMAtronic PQ24 0201
Shop #: WSC 00000 000 00000
VCID: 25411716EF410B36C75-515E
2 Faults Found:
01271 - Positioning Motor for Temperature Flap (V68)
000 - - - Intermittent
00898 - Control Circuit A/C compressor
010 - Open or Short to Plus
Address 09: Cent. Elect. Labels: 6Qx-937-049-C.lbl
Part No: 6Q1 937 049 C
Component: 00 BN-SG. 1S33
Coding: 00140
Shop #: WSC 06402
VCID: 3B75D16E29C5ADC6811-517A
9 Faults Found:
00511 - Selector Lever (E313)
49-00 - No Communications
00778 - Steering Angle Sensor (G85)
01324 - Control Module for All Wheel Drive (J492)
01044 - Control Module Incorrectly Coded
35-00 - -
01598 - Drive Battery Voltage
07-10 - Signal too Low - Intermittent
01312 - Powertrain Data Bus
37-10 - Faulty - Intermittent
01309 - Power Steering Control Module (J500)
01316 - ABS Control Module
Address 17: Instruments Labels: 6L0-920-xx0-17.lbl
Part No: 6L0 920 920 K
Component: KOMBI+WEGFAHRSP VDO V11
Coding: 00445
Shop #: WSC 00050
VCID: 3365F94E01956586591-517A
VSSZZZ6LZ4R056375 SEZ7Z0C2168128
5 Faults Found:
01322 - Control Module for Multi-Function Unit (MFA) (J501)
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: 62 GATEWAY CAN 1S33
Coding: 00014
Shop #: WSC 06402
VCID: F0EFB642B0039E9EE43-517A
8 Faults Found:
35-00 - -
Address 44: Steering Assist Labels: 6Q0-423-156.clb
Part No: 6Q0 423 156 S
Component: LenkhilfeTRW V260
Coding: 10121
Shop #: WSC 06402
VCID: 3F8DA57E3DDDB1E6AD9-515E
2 Faults Found:
Address 46: Central Conv. Labels: 6Q0-959-433.lbl
Part No: 6Q0 959 433 E
Component: J2 Komfortgerát 0002
Coding: 00065
Shop #: WSC 06402
VCID: 3D71DF7637D1A3F6BF5-4B36
Subsystem 1 - Part No: 6Q1959801A
Component: J2 Tõrsteuer.FS KLO 0003
Subsystem 2 - Part No: 6Q1959802A
Component: J2 Tõrsteuer.BF KLO 0003
1 Fault Found:
00849 - S-contact at Ignition/Starter Switch (D)
25-10 - Unknown Switch Condition - Intermittent
