2.0 TFSI Inlet Manifold Removal, Injector Replacement & Valve Port Cleaning Guide
Lee M
Hi All,
I've been meaning to get this posted up since I carried out the work in Feb. Took me a while to put together. :blink:
Guide Includes:
  • Removal of inlet manifold
  • Injector replacement
  • Cleaning the valve ports
  • Changingthe RS4 fuel pressure valve (with inlet manifold removed)
I have used the forums for a good few years now and have always found a wealth of knowledge and help from other members so I though it was a good time to do a ‘How To’ for this task and return the favour to the community!
I couldn’t find a guide dedicated the 2.0 TFSI engine in my Mk.2 Leon Cupra (1P - transversely mounted).
The PDF in the link is based on how I carried out the removal, with some of my photo’s and info & images taken from a few other forums/sites plus guides that I came across whilst searching for info.
Allow yourself a bit of time to carry this out without being rushed. This was my first time removing the inlet manifold, it is a fiddly task that takes a little patience, it took me the equivalent time of a weekend to remove everything, clean the valves and re-install it all.
http://www.scribd.com/doc/156031056/2-0-TFSI-Inlet-Manifold-Injector-Valve-Clean-Guide
I take no responsibility for any damage caused whilst following this guide.
Cheers all
Lee
Cuprarob112
403
Nice diy.
By the way, if it's just for cleaning the inlet/vakves etc. my dealer has a machine/equipment to get these parts all cleaned within an hour and the results are amazing.
firestorm
Newbie
Jun 28, 2004
18
Excellent write up Lee. How often do you have to do it?
The only thing I didn't like is accessing the document, scribd cripple copy and paste so that it doesn't work do well and charge you a premium to download or print it.
Lee M
No idea mate I'm afraid. It was a bitch to do so hopefully not a lot!
