Relay Panel
Cupra Kid
Has a TDI!!
Oct 13, 2005
3,380
Chesterfield, Derbyshire
Hi Guys
Can anyone tell me which relay does what on the relay panel. I've found it so I don't need help with that, just wondering if there is a relay related to the windows?
Pic added
Muttley
Catch that diesel!
Mar 17, 2006
4,987
31
North Kent
Relay positions are numbered from the top left on the upper, supplementary, panel: top row 1-6, bottom row 7-13.
Position 8 - Terminal 30 voltage supply relay (109)
The panel below that is the main relay panel with positions 1-4 left to right, and the big wash/wipe relay on the far right in positions V and VI (No idea why they are labelled with roman numerals)
1 - Dual tone horn relay (53)
2 - X contact relief relay (100)
4 - Glow plug relay (103)
V/VI - wash/wipe system: without rain sensor, without headlight washer system (377)
The number on the relay can is a code which identifies what the relays functionality is, so you may find another 53 relay in position 10 as a fuel pump relay on PD cars, or in position 13 as a radiator fan relay.
fahafiz
231
where do you find relay 109 on a Leon? should i replace the black one with a newer gray one?
Muttley
Catch that diesel!
Mar 17, 2006
4,987
31
North Kent
fahafiz: There is only one 109 relay on the board, and it's in the same place on Leons and Toledos, position 8, as shown above. If you have a left-hand drive car, then the relay positions are different, and that relay is in position 12
DarrenJ
Seat like you mean it!
Dec 3, 2008
470
Galway, Ireland
Thanks Lee.
I got new glow plugs put in but the garage said they kept blowing the glow plug fuse on top of the battery.
I just want to check everything is working ok. I don't have any EML on the dash anymore since they were changed but because they were blowing the fuse I want to check everything is making a secure connection.
I will use a phase tester and see if power is getting to the loom.
Michael Daly
Where does the fuel pump get it's power if there is no 53 relay in position 10?
