flyinlo
Hi guys,
I'm new to the forum. I drive a LC '08. I'm currently experiencing a few problems with my car and hoping someone can help.
My car recently started leaning out to a point where it's pinking at low rpm's. I had a low pressure fuel error on vag that was due to the thrust sensor on the hpfp. The sensor is now changed and I don't get the error anymore but still hasn't made a difference to the fueling. I've logged the hpfp (230 on VAG) and the specified and actual values are the same. The knock levels are high through out the rev range on all the cylinders. Could this problem possibly arise from the LPFP?
To date I have done the following:
-Changed the cam lobe
-Inspected the cam
-Changed to Iridium plugs (It's burning white indicating a lean mixture)
-Changed the thrust sensor on the HPFP
The car has JE pistons+rods because I was planning on going the BT route. I dont think this issue is a result of compression because the car drove fine for about 4 months. My car is currently standard and the only mod that I have on is the Autotech HPFP. Your help will be appreciated.
-Inspected the cam
