1.8t intercooler piping
Jun 21, 2008
673
Wolverhampton
Any body made there own pipework up to put an intercooler on there petrol FR? thinking of adding the SEAT intercooler to mine and forge dont list a piping kit for the 1.8t.
if you have, would you be kind enough to list what sizes and shapes are needed?
Ric 2001
Need an ID-ten-T form
http://www.forgemotorsport.co.uk/con...roduct=FMIBMAP is that the complete section to connect from the current pipes to the topp of the IC?
My above post for the map pipe will fit the to of the IC. If you buy that then your CURRENT FR pipe that is connected to the throttle body will not fit.
You will need the cupra pipe, which I posted up earlier. If you are going down this route then the FR pipe I have will not fit.
You'd end up with the top looking like this.......
Images courtesy of Hartosh
673
Wolverhampton
wicked. im going to look at the revised cupra pipework and make u pthe bottom half.
ive found ndless descriptions of the skin kit with the pd version, so i assumed the 20v kit had been pulled out of the market.
SWANSWAY CUPRA Dealership
