interior light
toaophil
264
Cupra Mk1
Hi all, I know this is a 'duh' question.. but how do i get the interior light bulbs out!? From the back of the car above the back doors?
Cheers toaophil
Muttley
Catch that diesel!
Mar 17, 2006
4,987
31
North Kent
Just done this to remedy a lack of light, which turned out to be just poor contact. There's a very odd bulb in there on my car, which has the ultrasonic sensors in the rear reading light unit.
Seat recommend a plastic spatula to avoid damaging the plastic light surround, which is fitted into a metal dish in the headlining. If you try to just pull it out you'll drag the whole thing through the headlining and it will be a bugger to get it repaired.
This is the nearside rear reading light.
Insert a broad, flat-bladed screwdriver here
Push in firmly and twist carefully
The unit hinges at the rear end, the clip you were pushing is now visible.
The black item is the base of the bulb
A quarter turn loosens it.
This is what the bulb looks like
The received wisdom is that it is a T5 Neo Wedge fitting
toaophil
264
thanks guys i'll give it a try. They certainly are a strange bulb. Not sure where to buy new ones from. I guess Seat charge the earth for one. Ebay maybe?
Muttley
Catch that diesel!
Mar 17, 2006
4,987
31
North Kent
The fitting seems to be called Neo Wedge. They come in various diameters. I think this may be a T5, but couldn't swear to it.
Muttley
Catch that diesel!
Mar 17, 2006
4,987
31
North Kent
I can clean this up for the FAQ if the mods think it's useful? There isn't anything in there at present.
