mk1 golf caddy/homemade 24v v6 4wd turbo
powernut
475
hi all i know this is gunna be stress but id thought id share ,as i may need some advise on this buggar,as ive facied a caddy for a while and always liked the mk1 golf caddy shape ,it was only when i went and called in at a local farm and found a mk1 caddy been used with a forlk life for a gate post,,coverd in nice green mold,so after chatting with the farmer i bought it ,as its in a poorly state at mo due to been stood for 7 years ekkk:(,so i eveturly got it home ,with nice brakes burnt out ,and sized wheels ,,
plenty of holes and rot too,along with holly floors too
so after a 2hour wash ,i can see potentioal
and that horried back is going plus the old 1.6 diesal and gearbox is too
powernut
475
so next thing i thought i need a power house ,and thought id do some modifaction to get a nice mk3 vr6 in it ,
yes i know these dont fit by just bolting in more mods are needed ,
then thought it will make the front end heavy so thought ill buy a complete 2001 mk4 golf 4 motion rear axle for some extra grip
asi was only going to make it 2wd drive ,i thought id better make it 4wd so bought a nice 02m 6speed gearbox to fit to my 12v vr6 lump
then sorted a proshaft and some spare drives etc
then thought these engines are only 174ish bhp ,erm and id had the ecu chipped to 200bhp i still wasnt happy ...so i thought id buy a transfor box and turbo kit etc for my set up
then fitted my gearbox starter ,part turbo kit and 4wd transfor kit to the engine
,thought id basicly get all the runing gear sorted saves hunting around at a later stage ,then i hit a small prob ,the rear golf axle is not only too wide but the ecu is called haldex and needs a controller to work ,this part from dealers called haldex ecu is 600..that just for this little box
and beteen 600 to 850 for a part to control the 50/50/50/100 all time 4wd system,so i thought chuff that ill make my own,after a bit of stress ive sorted the curcit ,stepper,and controller to make it work nice ,for either raceing or daily driveing,,
then dropped on some mk3 coil overs which im hopeing i can use mk1 top mounts,then shortern drives ,a arms quick pic here
just built the meqa squirt ecu up and cranked the engine and put a map on the ecu so it should run in theory lol,,,
powernut
475
oh i dint know mk4 r32 drives bolt sraight up in mk3 hubs saved a little job
and slightly skimmed the inner alloys to dish ,so they nicely miss the rear calipars and rear dampers
all fits well
and some alloys ther will have to do with a quick refurb at a later stage
right guys due to priming the bug etc ,i thought id make a manifold for the caddy vr6 and heres how i did it ,,3hours all done ,im just unsure which way the thottle body is supose to be,,
bit of drawing first
then a bit of drilling
bit of grinding
welded bolts in place
cut some tube and welded some steel
end plate for thottle body
quick grind around
powernut
475
grind ed it up
job about done ,just a couple of pipes and thottle hanger
i hope theres enoegh pics for u ...:thumbs_up
unsure how close it will be to the front ,as i just gessed,,,
powernut
475
right this afternoon i had to go and see if it would fit bolt up and weld servo and fuel reg pipes on fit and looks ok for a first attempt
evern pipes fit o too
then thought we might as well that manifold will be hot so make a quick cover for it ,a bit of bling or somert like that
fits ok ,
be nice when im ready to mod the turbo too,,,may look a bit more like a engine lol
powernut
475
little update not too mutch as im still filling the bug ,but i had a few hours spares so i noticed this pipe and im sure this is why i had a water problem ,
anyway i went and bought a r32 golf thermostat houseing so i cann select 5th and 6 gear due to the std vr6 themostat was in the way
these are the too houseings
then made some bolts
nice fit in the r32 houseing
notice the std vr6 and the r32 tube lengths
so houseing pipeing fitted and std vr6 sensors fit in the houseing too
decided i dinr want power steering so removed all that along with the aircon bracket ,so i can add somert at a later stadge to the engine
belt pulleys sorted
powernut
475
decided to use differnert type of ht leads
and polished rocker as well tidys things a little
powernut
475
some engine problems,got the engine runing on the floor,and 10mins of runing ,a horrible noise came on ,so its bloody strip down again ,stress,mind im glad it wasnt all fitted and this happernd on a test run..
problem a little end on one piston and i need some more piston skimming too,,for more boost.and timing chain guid smashed
so made the flywheel fixed ,to make sure it will hold bhp
started building engine engine back up 2day ,as i thought chuff the head spacers ,get the lathe out and skim em lol
powernut
475
more engine build ,,,carnt wait to start the dam caddy lol
therd some bolts and bit of welding for the flange
powernut
475
had to make a head spacer needed the compression lower ,,
then its start chopping the rear axle to size
rewelded it up in place
then got a bit ampage on the go ,,i dont want these snapping off
axle shorternd
next antiroll bar needs shorterning so instead of choping welding ,i decided to heat and bend it
sorted
double checked measurement
just a mock up with the caddy tailgate ,and it should fit,,
powernut
475
made a return pipe ,had to weld it in 5 places to get it right
i finaly got a steel one to fit lol ,so carried on with the homemade headspacer ,chuff buying when u can make one
so carried on with may home head spacer lol
once the runing gear is sorted ,its caddy modifying time
powernut
475
hi all not to mutch happerning at the mo ,,,but ive a little update ,a small change in plans lol ,im not going to use a old mk3 vr6 turbo ,that ill go on ebay ,ive decided to try attempt fit a later mk4 4motion 24valve engine and turbo that instead ,so started again as im more happy with this idea so heres what i bought,as i couldnt leave it right bargin..
head off all valves re seated and skimmed
ill be makeing another turbo manifold,inlet manifold,etc
powernut
475
COUPLE OF MODS THIS AFTER sorted oil feed and couple up,remove old cam sensors ,ill not need them made a plate ,
fitted coil pack
next i need to get the ecu sorted and wireing
IM CHUFFED HOW TURBO IS SAT ,NOT TOO HIGH so bonnet should shut in theroy lol
powernut
475
modifyed some nice decent size cc injectors ,
intake manifold to make next ...
and a few tuning bits arrived too,,
also added lunch control for tracks and a stand alone rev counter ,,,
powernut
475
bit of work started on the caddy this after rip the rear hood off ,ripped the oil 1.6 oil burner and box out exahust off ,gearlinkage out
pedal box out,found a few more rottern parts eg rear floor,rear roof,bits on inner wings ,
powernut
475
few mock up pics of were ill roughly fit it
as u can see fitting this isnt going to be hard at all ,
bit of cutting choping here and there and that bit ill be mounted ,
then ill mod the power steering as well,
rip the tunnel out ,fit another ,algine prop ,and adapt tthe rear axle ,,
everthing ive thought off so far isnt no were near as bad as first thought,
bit more done on the mk4 turbo lump too,,,
powernut
475
oil return sorted and a start on the inlet manifold this afternoon
home made oil pipe,every little bit comes in
removed sumps as the early steel one fits and is cheeper to replace if i hit a hump lol
powernut
475
engine comeing along nicely now ,,,
soon be ,,caddy moding time ...carnt wait ,,,lol like a kid in a sweet shop
had a spare hour 2day so modifyed the from wheels,suspension, couldnt see point of useing mk4 subframe after some further thing,wishbones,to fit 5stud ,not my ideal choice of alloy but they will have to do at mo , ,least the big discs should stop a little better then the std 4stud jobys
sorted another homemade mody ,fit central and pimped lmao
powernut
475
trail fit the engine 2day ,as i reckon it will fit fine ,evern with the 6speed as i thought i was going to butcher the inner wings out ,,some things will be a bit tight but i aint going to worry about them ,,my home made turbo fitsand has lots of room ,still ill have re locat the extrenal wastegate
just made a start on the short runner
bit of bending here and there ,and it will fit ,
i reckon ill get a radiator and fan thown in there
may have to find another place for the intercooler
powernut
475
few more bits done and started 2day
welded pipes on short runner
,i need to angle it more ,ill sort this no probs
trail fit of the propshaft
those garden bricks come handy lol
riped the old rear axle off, and oh dear dam std golf is short as well ,what a suprize
then thought ill trail fit the rear 4motion axle ,and yes,,more stress ,i shorted it too mutch ,as i only tuck a outside measurement of the tyres ,forgot about the thickness ,,lol
as u see from the rear wheel,looks ok thow ,so recut and welded a bit more on ,
seems better
