Hi guys,
I know I could search for each individual code and try and work out what they mean, but I'm in a huge hurry (car is meant to be getting traded in soon), and need to sort the following out ASAP:
5 Faults Found:
17608 - Boost Pressure Control Valve (N249): Mechanical Malfunction
P1200 - 35-00 - -
17544 - Fuel Trim: Bank 1 (Add): System too Lean
P1136 - 35-00 - -
16622 - Manifold Pressure / Boost Sensor (G31): Signal too High
P0238 - 35-00 - -
17705 - Pressure Drop between Turbo and Throttle Valve (check D.V.!)
P1297 - 35-00 - -
16490 - Manifold / Barometric Pressure Sensor (G71) / (F96): Implausible Signal
P0106 - 35-00 - -
Now, what is the N249, I hear it mentioned a lot, but don't actually know where it is in the engine bay, how much is it to replace (just the part), and does anyone know the VAG part number for it?
Fuel Trim: Bank 1? is this referring to the pressure in the rail, or the pressure for injector 1? If its the rail, would this indicate that the rail has a pressure leak, or that the fuel pump needs replacing?
Sensor G31, where is this, would this be caused by the next fault (pressure drop?), or would it more likely be a failed sensor?
Pressure drop between turbo and throttle, check DV. Well I've "checked" the DV, it isn't loose, I also get the same error if I use a forge 007p or the stock DV, so could something else be causing this (the N249 issue perhaps?)
The final error I assume is a sensor failure, which sensor would this be?
Any help is much appreciated guys, I'll owe you all big time after this!
5 Faults Found:
P1200 - 35-00 - -
P1136 - 35-00 - -
P0238 - 35-00 - -
P1297 - 35-00 - -
P0106 - 35-00 - -
