Arosa radio wiring
johnmac
Can anyone please tell me where I can get a wiring diagram or pin-out for the Arosa (2001) radio power plug? I need to adapt it to a radio with standard ISO power socket config.
Thanks in advance.
johnmac
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
as close as i can find - can't imagine it would be different but double check em anyway
note supplied as per leon aura unit c/o www.icecavern.com
All viewed into connector on head unit
Section 1 - Not all of these are available on the Aura v4 (Headphone, Telephone, External Display)
1 Not Connected
2 Not Connected
3 Headphone Out GND
4 Headphone Out L
5 Headphone Out R
6 Switched (+12V when unit is on)
7 Telephone Audio In Signal
8 External Display Clock
9 External Display Data
10 External Display Enable
11 Remote ( Not sure of its function )
12 Telephone Audio In GND
13 CD Data In
14 CD Data Out
15 CD Clock
16 +A CD (Not sure of its function but related to CD changer)
17 Switched Power to CD
18 CD Audio In GND
19 CD Audio In L
20 CD Audio In R
Section 2 Speakers
1 RR+
2 RR-
3 FR+
4 FR-
5 FL+
6 FL-
7 RL+
8 RL-
Section 3 Power
1 Speed Sense Wire
2 Telephone mute - Active low - Take to 0V to mute
3 OBD Diagnostics
4 Switched Ignition +12V
5 Antenna control (+12V when unit is on)
6 Illumination
7 Permanent +12V
8 Ground 0V
Attached image(s)
johnmac
Thank you very much Fl@pper, especially for the quick response. I'll have a go and let you know how I get on.
johnmac
