Innotec 'Turbo Clean Set'
adiniwasi
Has anyone out there used the above product on their turbo?
There is an interesting article this month in Volkswagen Driver about it for turbos with overboost problems and sticking vanes etc.
Any testimonials...?
mr-cbr
hi getting mine done today will post reply tell you what its like
mr-cbr
hi got mine done yesterday WOW what a difference had problems with going into limp mode not any more engine more responsive cost was 30 quid for kit and 100 quid labour + vat but it worked alot cheaper than a new turbo.
adiniwasi
Interesting. What explanation were you given for needing a new turbo?
Were you having problems starting from cold and was your acceleration jumpy or sporadic?
mr-cbr
told might need new turbo due to carbon contamination causing vanes to stick and making turbo overboost thus going into limp mode. got local vag specialist to do job as its a bit of a pain to get to turbo.
adiniwasi
Anybody know a vag specialist or deisel competant mechanic in Glasgow that might have experience doing this?
mrk
206
jr volkswagen in linwood or bedrock veedubs in motherwell are the only 2 i know of anywhere
Feb 1, 2007
1,602
Nottingham
Where did you get hold of this product?
Got mine direct from innotec 3 days ago cost £36 inc vat delivered
Getting the turbo cleaned sat afternoon. Alreday had the cleaner throught the fuel system which has on its own made a difference. Cant wait until I get it back sat evening:p
Glynn
adiniwasi
Nice!
Do you not have to be in the industry to get it off their website? Or did u just make up a company name?
ini
63
The inexpensive DIY method
With a cold engine, unbolt the CAT/exhaust from the turbo (3 bolts).
Liberally spray 'oven cleaner' (£4 carbon remover) into the exhaust side of the turbo.
Work the VNT mechanism for 5 minutes.
Leave for 1 hour.
Give it another spray (aerosol or foam), then work the VNT actuator lever again.
Mop up any remaining liquid
Reattach the CAT, and go for a long drive.
VNT mechanism unstuck.
Not sure if i would use oven cleaner on the CAT, maybe a citric acid cleaner etc.
1,602
Nottingham
Right just got my car back after being treated the innotec way.
My car has had a remap to approx 190bhp
Check out the figures I have posted in the thread performance stats
Glynn
