RPM max for 2.0 TFSI
GroovyBaby
Hi, I will own a new Leon 2.0 TFSI 200 HP in a week.
I have got a question : what is the RPM max for the 2.0 TFSI 200 and for the 2.0 TFSI 240 ?
yell_oh
58
Optimum shift-points
(RE: FR, Not sure about Cupra)
It seems the "soft" rev limiter starts to cut in around 6800rpm and may let you briefly touch 7k
However, I've done a spreadsheet to analyse optimum shift points and it's actually better to shift at a tad over 6500rpm, otherwise the torque drop-off becomes worse than the hit of the higher ratio of the next gear (except for 1st to 2nd shift, which is best to max out)
